rear caliper with parking brake
pablogustav
Post by pablogustav » Tue Jun 26, 2018 12:48 am
Hello there,
I have had every component of my brake system rebuilt by Karp's power brake in CA. I am experiencing inconsistent pedal movement and Karp has recommended that the rear calipers may be the culprit. I have bled the system very thoroughly, but when I pump the pedal about 4-5 times it feels perfect and on the next pump it may go down to the floor of close to it; then back again to feeling right. Karp mentioned that these brakes may require an adjustment to keep or set the piston close to the rotor so that when the cable is pulled that the piston does not have far to travel to set the brake. Any insights or info would be so much appreciated! thanks very much.
Re: rear caliper with parking brake
Post by dinoverde » Mon Jul 02, 2018 7:55 pm
send me a pm i will walk you through it
Post by Dario » Sat Jul 07, 2018 9:33 pm
Hi, does "every component" include the master brake cylinder? The symptoms you describe seem more the the MC than the calliper: The Dino has two separate brake lines. If there is a problem with the rear callipers, the other line (to the front brakes) will keep the pedal from going to the floor. BTW, did you bleed both nipples on the front callipers?
good luck,
Post by ThomasK » Sun Feb 10, 2019 8:19 am
It would be Great to get an Update if and how this Problem was solved so all others can participate. KR Thomas
Post by dinoverde » Wed Mar 13, 2019 7:00 pm
it is critical that these part be installed on the new rear pistons
http://www.dinoparts.eu/EN/fiat-coupe-s ... brake.html
