upper front suspension arm
mikespain
Post by mikespain »
could someone post a picture of the front upper suspension arm mountings.Does the rear one have shimming washers either side as when offered up into the mounting point there is about 1 cm play either side of the bush-As someone else removed them I am not sure about it,in the parts manual there does not seem to be any shown,only one forward of the front mounting.
any clarification would be much appreciated
thanks
mikespain
sorted
Post by mikespain »
The Owner had got the bushes the wrong way round as I suspected
Re: upper front suspension arm
if you send me a pm i will send you pictures of how the bushings should be mounted..
The shims go in front.
Hervé
Post by Luis A »
Hi Hervé, can you post the photos here for everyone’s reference in the future...?
Luis
here you are
more
more
more
