rear caliper with parking brake
Posted: Tue Jun 26, 2018 12:48 am
by pablogustav
Hello there,
I have had every component of my brake system rebuilt by Karp's power brake in CA. I am experiencing inconsistent pedal movement and Karp has recommended that the rear calipers may be the culprit. I have bled the system very thoroughly, but when I pump the pedal about 4-5 times it feels perfect and on the next pump it may go down to the floor of close to it; then back again to feeling right. Karp mentioned that these brakes may require an adjustment to keep or set the piston close to the rotor so that when the cable is pulled that the piston does not have far to travel to set the brake. Any insights or info would be so much appreciated! thanks very much.
Re: rear caliper with parking brake
Posted: Mon Jul 02, 2018 7:55 pm
by dinoverde
send me a pm i will walk you through it
Posted: Sat Jul 07, 2018 9:33 pm
by Dario
Hi, does "every component" include the master brake cylinder? The symptoms you describe seem more the the MC than the calliper: The Dino has two separate brake lines. If there is a problem with the rear callipers, the other line (to the front brakes) will keep the pedal from going to the floor. BTW, did you bleed both nipples on the front callipers?
good luck,
Posted: Sun Feb 10, 2019 8:19 am
by ThomasK
It would be Great to get an Update if and how this Problem was solved so all others can participate. KR Thomas
