How do I remove trim Dino coupe 2000?
bhiggins2
Post by bhiggins2 »
I need to make a repair to the lower section of the front wing panel on my coupe, above the front right jack point. I would like to remove the stainless steel rocker trim. Can anyone tell me how to go about removing this piece of trim? Thanks, Ben.
4cambob
Re: How do I remove trim Dino coupe 2000?
Post by 4cambob »
I would use a thin wide metal spatula and slide it between the bodywork and trim ,note there are two clips within that you must avoid,then gently ease the trim off. Do not use screwdiver or similar as this will mark the paint and trim.
bhiggins2
Post by bhiggins2 »
Can anyone point me to what the trim clips look like?
Thanks, Ben.
4cambob
Post by 4cambob »
bhiggins2
Post by bhiggins2 »
Thanks. That is helpful to know I am dealing with a round plastic clip below the trim. Ben.
