Here is how I replaced the rusted clips that hold the stainless steel rocker trim on my spider.
The original clips (2 per side) looked as though they were part of the titanic. I purchased some galvanized sheet metal and cut it to a slightly larger size then bent the edges over for more strength.
Then put a curve into it and made a hole for the bolt. Stainless steel hardware.
If the fitting was too loose I just had to flatten the curve a little.
A simple job
Fiat Dino Rocker trim clips
- fredfrey
68 Fiat Dino Spider, 73 Giulia Super, 66 Giulia Super, 71 Fiat 500, 72 GTV, 83 AlfaSud, 74 1600 JrZ, 2012 Abarth
Re: Fiat Dino Rocker trim clips
Colin at Super Performance in the UK now has these. He had them remade.They are a very complicated design!
I am still looking for one chrome trim though............Lost it during the last 20 years!
David
BC.Canada
Spider #237
David
BC.Canada
Spider #237
Thanks for the picture tutorial!
I am attaching the strips to my dino 2400 coupe project now, but luckily got hold of some plastic new clips.
But I will keep your procedure in mind when it does not fit.
Leo
Dino Coupé 2400x2
The Netherlands
Dino Coupé 2400x2
The Netherlands
Original ones here from Colin # FIA04325
http://www.superformance.co.uk/a-fiat/fittings.htm
David
David
- fredfrey
It was a very simple how-to. I just wanted to get the ball rolling here.
What SF sells is needed but not what I replaced. I did not see the end screw-in parts on the site.
You are talking about this right:
Yes......!! I still need one chrome trim though...Any ideas?
I came across this site from a Google search - they have sill trim clips for Dino Spider and stock 124 Spider chrome sill trim but not Dino I'm afraid.
http://www.historic-cars.net/historic-c ... upe-Spider
Ross in NZ
Ross in NZ
