Folks,
Can I check the correct assembly for the oil pressure bypass valve on the oil filter housing.
I reckon it is as follows but thought it would be good to check!
Insert the valve with closed end first,
Then spring inserted into open end of the valve,
Then the o-ring,
Then adjuster.
Regards, Paul.
Oil pressure bypass assembly
