My door mirror is falling off. It is not immediately obvious how the door cards come off. Can anyone help?
Rob
2000 Coupe door cards
- fdus172
Re: 2000 Coupe door cards
Remove the vent window hardware. Then the chrome strips on the front, rear and bottom. The arm rest is a pain. There is one screw at the front, reached from underneath ( you should be able to see it). The rear is held by a screw that is inside. Look for a small hole in the vinyl, on the underside. A small phillips screwdriver and lots of patience. Then the door latch handle. The card can be pulled out from the chrome strip on top. Do not try to remove that top strip! there are too many tiny, hard to find screws.
Rick Wohleber
Portland Oregon
Rick Wohleber
Portland Oregon
