timing chain tensioners
vjim
Post by vjim »
Hi ,
First i would like to apologise for my english ( i'm french , nobody's perfect :mrgreen: )
I have a 1968 fiat dino spider , and i would like to adjust my chain ( it's the earlest adjustors ).
No problem to do that , but on one side i didn't have the stretcher screw . So i order it and i received this :
I don't understand why the part on left is not flat on the two sides ? Can somebody explain to me how i can put it before the screw ?
thanks
Ps : my dino
vjim
Re: timing chain tensioners
Post by vjim »
You can see that at the bottom , it's flat so i don't understand how the part can be stick
dino176
Post by dino176 »
The part to the left is the one that goes first into the engine block, secondly the treated bolt. The left part pushes direct on the chain tensioner. It is difficult to see from the picture, but the left part is most probably still sitting in the engine block. Try to use a magnet to extract the part.
vjim
Post by vjim »
Look here
i think i have tensioner ( with flat portion , i see it at the bottom it's flat , so the part i have can't be use ) part 4181173 and i need part 4178684 to lock it.
