Fiat Dino Coupe 2400 rear windows
Benz 116 w
Post by Benz 116 w »
Dear Friends, I have a problem with the rear side windows. My mechanic is not the same guy who took the car apart. The windows would not wind up to the door frames, whatever we do with the lever mechanism. Approx.2-3 cm-s are still missing to the gasket/seal. He says there may be an other tilting mechanism inside the C pillar. Is it true, or any idea why the windows won't go all the way up?
Looking forward to your quick replies, thank you, Zsolt
Re: Fiat Dino Coupe 2400 rear windows
Hi Zsolt, there is no further mechanism than the winding gear with the black knob. I attach the relevant page out of the Fiat spare parts catalogue. Perhaps, the gear is defective?
Finestra laterale.pdf
(1.07 MiB) Downloaded 433 times
Benz 116 w
Thanks Georg, will forward it to my mechanic tomorrow the earliest. Will keep you posted! Cheers, Zsolt
Benz 116 w
Dear Gregor! Your diagramm solved the problem, thank you. Both screws were cut off, my mechanic is now fabricating new ones. B/R, Zsolt
