coupe boot hinge pins
4cambob
Post by 4cambob »
Can some one tell me what the correct part for the coupe boot hinge pin is,or even a photo if possible.On my car (2.0 coupe) I have a chromed bolt with a rather flat head going through the bush that is factory welded on the car,then the hinge is positioned over the bolt and its held in place with a nyloc nut.On the other side someone has welded a clevis pin so once the hinge is in place they used a cotter pin to locate it.I would also assume that the hinge should rotate over the hinge pin instead of the hinge pin rotating in the bush that is welded in the car,could some one also clarify if this is correct.
