Page 1 of 4
Ignition switch Issues
Posted: Wed Feb 22, 2017 12:34 pm
by Christopherevans52
I have a 1972 Dino Coupe 2.4 with a temperamental ignition switch, Sometimes you turn the ignition on and the gauges fail to come live i.e. the fuel gauge doesn't switch on, you can turn the engine over but it won't start. by wiggling the key or tapping the casing under the key it will come live then starts fine. Once going it is usually fine or though has died on a couple of occasions.
I had the whole barrel out a couple of years ago, soaked it in WD40 and re assembled it which worked for a few months. I also tried to fit the Superperformance replacement switch which had different wiring and then fell apart in my hands!
Any help welcome - is it the same as a 124 switch?
Re: Ignition switch Issues
Posted: Wed Feb 22, 2017 10:12 pm
by Georg
Hi Christoph,
No, the switches of Dino and 124 are different. Dino has a male connector #16 which supplies the fuel pump with power when starting the motor. The 124 does not have this.
I have some new original Dino ignition switches left and would sell one. Kindly give me your email address (in a PM) so that I can send you some photos of this item.
Posted: Thu Feb 23, 2017 2:44 pm
Posted: Sat Mar 04, 2017 6:16 pm
New switch in and working perfectly - thanks Georg
Posted: Thu Jul 13, 2017 5:53 pm
by PeterW
Please excuse me joining in this discussion. I own a low volume Italian car built in 1966, which I am informed used the same ignition switch as a period Fiat Dino. My car, unfortunately was broken into 40 years ago and the ignition switch was vandalised and replaced with a Lucas ignition switch. I am attempting to return the car to nearer its original state and so I am looking for a SIPEA 90030 ignition switch/steering lock. I have the original contact set, though not the lock barrel. I have been informed that the FIAT part number for the ignition switch is 4186512, and the SIPEA contact set is Sipea 606730. But I can't guarantee that the info is correct. The ignition is definitely a SIPEA 90030 though. Also, as I have the contact set, I do not require a switch with the same contacts (though that would be nice). If anyone (Georg perhaps) can point me in the right direction, I will be eternally grateful.
Posted: Sat Jul 15, 2017 7:49 am
by Georg
Hi Peter, please check the photos below if this is what you are looking for. At least the # 90030 is stamped on the front side. If you are interested kindly send me a PM to agree on price and clear sending the item to you (in which country do you live?). Alternatively, if you do not have access to send a PM, let me know your mail address.
Posted: Sat Jul 22, 2017 9:35 am
by PeterW
Goeorg, Many thanks. Alfredo from DinoMania has helped me out. Thanks for following up though. It is appreciated. Kind regards, Peter
Posted: Wed Nov 01, 2017 5:30 am
by Luis A
Hi Georg,
Could you please contact me at
LArisso@att.net
Thanks, Luis in USA
Posted: Sat May 09, 2020 6:30 pm
by Scalino
I'm having similar (not exactly the same) issues as the OP. I want to take the ignition switch out and see what's going on and try to repair it using this tutorial:
https://www.mirafiori.com/faq/content/switch/index.html
Not exactly the same switch I believe, but I guess the procedure is the same and worth the shot before buying a new one.
I however can't seem to get the damn thing out. I know you have to push the spring inside the small hole on the first picture, but it seems stuck on the side of the steering column.
I've read on some Lamborghini forum that there are two screws and one bolt. I've taken out one bolt and one screw. Could someone enlighten me wether I've missed a screw/bolt?
Posted: Sun May 10, 2020 1:18 pm
by Georg
Scalino, yes, take out the screws (one or two, cannot remember), then take a small screwdriver, press in the pin, and then turn the ignition key. At some point you will feel the pin moving deeper. I believe it is the ignition position 15, not the starting position. Only then you can press in the pin that much that it releases the lock and you can pull it out.
