hardware re plating. What is correct what is not?
Re: hardware re plating. What is correct what is not?
Hi Richard
Can you tell me what the width of the material is? If you could post a picture of the back of the material.. I am thinking about having some reproduced.
Since we have access to such an original car , we should take advantage of it to try to reproduce of the parts not available.
I am also working on having the dash corner pieces reproduced. They are missing on most cars. Richard if you could post a picture..
Hervé
Hervé
Many of these top latches have been chromed but it appears that on 3 very original late model spiders I've seen they are not chromed. Note strap behind.
Also trunk mat material underneath.
detail molding below rear valence and on sides of engine compartment lid. Known as either L5 or F1 on Re-originals" profile page for engine lid, a larger version for the valence in the rear, which were riveted on originally.
The small plastic pieces on the dash corners.
- Attachments
- IMG_2962 (2).JPG (27.09 KiB) Viewed 12881 times
The proper plating underneath: Note; special exhaust clamps.
Original R.I.V. shocks and their true color.
Details on the piece between the dash and the door post.
Many thanks Richard, this is such a valuable archive for our community.
Thanks a lot so informative.. everyone should copy and save these pictures..
I am so surprised a bout the plastic trim on the side of the hood. I went and saw the car at fantasy junction and it has also the same trim..as well as the same trim for the trunk.. very informative..
Thanks again
Hervé
PS:If you could also post a picture of the back of the top limiting straps(with a width dimension)
Thanks again
Hervé
The limiting straps look the same on the back and are 3". Glad to help.
