Where to buy door seals
Does anyone know where I can buy the small door seal for the 2lt coupe. The one that goes on the trailing edge of the front wings,also the door shut and below the Bertone stainless sill trim. It has a D section of 10mm.
Re: Where to buy door seals
Have you checked Cicognani?
I've bought a door seal kit from DinoParts once and had no reason to complain.
Thanks Scalino and Tobi. The Cicognani site only sells it as a set of which I do not recognise two of the included seals. The Dinoparts set seems better but they don't sell it separately . One possibility is the door shut seal on a 246 gt dino which I can buy on its own but I am not sure if it's identical.
I just bought from Elvezio.com in Italy.They shipped just before the Corona situation happened.
I am happy with the quality of the door weatherstrip they sent.
Good luck!
Mike in Chicago
Good luck!
Mike in Chicago
Thanks for the link Mike. However the only seal I could see was the upper seal which I do not need. Do you have the relevant part number .
