Balancing Crankshaft/Pulley/Flywheel
Bijan
Post by Bijan »
Hi all,
I was just wondering how the crankshaft is balanced in the 2.4-litre engine.
Is it balanced together with the pulley and/or flywheel?
Or is everything balanced separately?
The reason I ask is that I would like to put a trigger wheel on my pulley.
Many thanks
Best regards,
Bijan
Re: Balancing Crankshaft/Pulley/Flywheel
Post by Ribolla_67 »
Hi Bijan,
This is the original workshop manual description
(Download from FChat)
First, balance without flywheel and damper.
Then repeat balancing procedure with complete assembly
Post by Fanalone »
To my best understanding, the cranckshaft is externally balanced by the flywheel & the harmonic balancer.
You can clearly see the counter weight`s on the backside of the flywheel & balancer.
Erik
