Now all throats are synchronised and the idle mixture set, it runs very well I would say, a massive improvement pre carb overhaul.
Slight bummer, the battery isn't charging, so we'll have a look at that now...
 . The plug with the yellow and grey wire wasn't plugged in. To my defence, one end is actually a plug, but on the other side they didn't bother to put the right connectors for a plug on, hence there is no plug on that end. Not a great description I know
. The plug with the yellow and grey wire wasn't plugged in. To my defence, one end is actually a plug, but on the other side they didn't bother to put the right connectors for a plug on, hence there is no plug on that end. Not a great description I know  .  Generally the wiring is just a mess, so it isn't immediately obvious when there is a loose connector...
