Fuel Tank Sending Unit
Posted: Tue Dec 22, 2020 6:57 pm
Happy holidays to all on the forum! Let's move on to a better 2021. My question is about the fuel tank sending unit, specifically on a 2.4 spider. The 2.4/2.0 coupes and 2.0 spiders may fall under this question as well, but I have not researched their specific wiring diagrams. The wiring diagram I have shows the two wires that attach to the sending unit, one controlling the low fuel indicator light and the other driving the gauge. The wiring diagram also shows the sending unit going to ground. All makes perfect sense. In my car I had to deal with some seepage at the tank so I removed the tank for repair & re-coating. All good. While the tank was out I renewed the rubber on the tank straps and body of the car to prevent any metal on metal contact and/or chafing. So..... the fuel tank is essentially isolated (electrically) from the car body. There is no ground wire that I am aware of from the tank or sender that would complete the fuel tank sending unit circuit. Easy problem to solve, but what has me scratching my head is what mechanism did the cars use from the factory to ensure the fuel tank sending unit is grounded so the gauge and warning light would be functional? It seems the all encompassing, Italian car electrical diagnosis applies here.... IAABG (It's Always A Bad Ground!) Just curious what the thoughts of others are on this issue.
Social distancing is best performed at 6000 rpm on a nice sunny day........
