Dino 2.0 Coupe Window Motor Wiring
Posted: Wed Jul 27, 2022 9:30 pm
by mmmmoto
I have purchased a new window motor for my 1967 Dino coupe from Superformance. It came with one red and one black wire.
The old motor that has failed has 4 wires, so I am at a loss as to how to wire the new motor into the car.
Can someone point me in the right direction?
Thanks!
Mike
Re: Dino 2.0 Coupe Window Motor Wiring
Posted: Fri Jul 29, 2022 12:25 pm
by Dinoswede
This subject has been discussed before. Search the Forum for "Wiring electrical window" from June, 2020.
If you want the keep your original window switches, you have to include a polarity change relay - like the relay
shown below - one for each side:
At the original switches, use only no 2, 5 and 4 connectors. No 1 should not be used, so disconnect completely.
Connect the blue wire (FWD) to no 2, the black wire (0V) to no 5 and the the green wire (REV) to no 4.
The original + 12V power wire, connected to no 5 (grigio/rosso or azurro), should be connected to V+ connector
at the relay, and 0V connector should be connected to the ground (chassis).
M1 and M2 are the power feed connections for the window motor.
Posted: Mon Aug 29, 2022 12:16 am
by bhiggins2
I came across this diagram when I had to replace a 4 wire motor with a new 2 wire motor. It works but if you are replacing with a 3 terminal switch, the lower diagram works well.
Ben Higgins
1967 Fiat Dino Coupe
