Differental Noise - any recommendations for repair. RESOLVED!!!
Posted: Mon Jul 03, 2023 11:37 am
Hi Guys.
I'm a new Dino 2400 owner and the first of probably many problems has reared its head.
Symptoms are: Loud grumbling noise from the back when turning even very slightly, you can hear it from both inside and outside of the car, it's quite alarming. When driving in a perfectly straight line, it's fine, no vibration, no noise, but the moment you start turning, it comes back.
What I've determined so far. Diff oil is full to the brim and I presume it's the right stuff - SAE 90, and it looks reasonably clean. Some work has been done to the diff in the past - the bottom finned plate (it's like a sump plate) has previously been removed and refitted with new sealer. Some leaking is evident, from what I suspect to be the output flange seals, though not excessive.
Jacking the car up on one side, the free wheel will not turn, as if the handbrake was on. Jacking both sides up and the wheels turn with each other in the same direction, as I believe it should for an LSD. The moment you stop one wheel from turning, the other won't turn.
Can anyone recommend anyone in the South, ideally in the Oxon/Berks area who can rebuild these LSDs? Thank you!
Thanks!
Thanks!
