Magneti Marelli BZR 205A ignition coil
Posted: Tue Apr 16, 2024 1:23 pm
I spotted a discussion at the Forum re why the BZR 205A ignition coil has 3 connectors, instead of the "normal" 2 connectors.
The special feature of this coil is that the primary and secondary windings are not sharing the same ground (earth) connections.
Other "normal" ignition coils have their two windings connected to ground at the same point.
But the Dinoplex AEC101 can only be used with a coil having this feature, otherwise the electronics will be damaged!
This is the only reason for having the "3 connector coil".
When switching to "Emergenza" mode, the AEC 101 electronic circuits are completely bypassed, so the BZR 205A primary coil
is connected directly to +12 Volt and ground (through the breaker points), as in any "ordinary" breaker points ignition.
