Installing a Dinoplex
Posted: Tue Aug 27, 2024 1:20 am
I’m putting a new Dinoplex in my car.
It had an MDS 5 in it before.
I’ve got all the wires to the coil and distributor correctly hooked up. I took the wiring distributor on the Dinoplex off and double checked.
The MDS 5 had a wire run from the ignition switch. I hooked this to the power in on the unit.
Question do the blue and brown wires have to be hooked to the coil as shown in the fiat wiring diagram?
Both the red wire from the ignition switch and the blue from the starter have power when I turn the ignition on.
But I am not getting any humming sound from the Dinoplex.
I did check the two oil pressure wires are on the right sender. ( I had the engine out for steam cleaning)
Engine turns over strongly and new fuel system is pumping strong.
Mañana I’ll have a friend help me check for spark.
Thanks in advance
Thanks in advance
