Page 1 of 6
				So what did you do to your Dino today?
				Posted: Wed Nov 20, 2013 10:59 pm
				by The Dutch Dino
				The official thread to let everyone know how your Dino is keeping you busy and what you did with or to it.
				Re: So what did you do to your Dino today?
				Posted: Wed Nov 20, 2013 11:00 pm
				by The Dutch Dino
				Today I stored it for winter... They started putting salt on the roads again... It's below zero again here at night.
Salt and Italian steel. Not a nice comination.
				Posted: Thu Nov 21, 2013 8:42 am
				by alh
				Started to disassemble it for getting it back to the original paint color over the winter.
Good timing, looks like the rainy/snowy season started here yesterday, so would not be able to drive it anyway.
				Posted: Thu Nov 21, 2013 6:55 pm
				by kurfuerst
				My Dino is immigrating today to his new homeland. OK, it's not fair to leave Italy for this weather ...
				Posted: Thu Nov 21, 2013 10:05 pm
				by The Dutch Dino
				So now that my driving dino is off the road for winter, And my Porsche 928 is running again, I finally have some time to spend at the other dino project car. Always something to do...
				Posted: Mon Nov 25, 2013 5:27 am
				by doublegarage
				Today I removed the oil feed lines from my 2400 Coupe's auxiliary vacuum pump so that I can take them to be remade with new hose and hopefully stop the oil leaks.
This thing might be the most unnecessarily complicated 'thing' on any car I have ever owned - it's an air-pump (therefore plumbed into the vacuum system), it's oil-lubricated (therefore plumbed into the cylinder head's lubrication system) and is driven by an electric motor, with a relay, and a pressure switch, and a fuse.   And it's rubber mounted. And the hanger for the windshield washer reservoir bag is welded to it.
Does any other car need an aux-vacuum pump?
				Posted: Wed Nov 27, 2013 10:28 pm
				by fdus172
				Today was polishing of the right door trim pieces prior to final install of the door card.   Restoration is nearing completion !!
				Posted: Fri Nov 29, 2013 12:57 pm
				by kurfuerst
				Today it's the first day for my Dino in Berlin.
On the one week journey to Berlin the car had rain and snow for 45 years.
				Posted: Fri Nov 29, 2013 8:31 pm
				by UroTrash
				Today, after a careful warm-up period, I gave my Dino an Italian tune-up.
				Posted: Mon Dec 02, 2013 1:35 am
				by doublegarage
				Today I replaced the alternator (see technical section)
- and replaced the voltage regulator
- and fixed the door locks
- and painted the horn compressor
but couldn't test drive it because one of the aux-air-pump oil-feed lines is away being repaired.
