Brake booster pump wanted
beebee246
Post by beebee246 »
Can anyone sell me a brake booster pump for a 2400 coupe/spider please?
Brian Boxall BS1319
Re: Brake booster pump wanted
Hi Brian
if all fails...i can give you a number in Oakland of a good electrical shop that restored one for me..not cheap
Hervé
Brian
You should contact Luciano at Casa del freno in Modena. He repairs BONALDI brake booster pumps. Call him on his mobile 0039 334 2911923.
http://www.casafreno.com/
beebee246
Post by beebee246 »
Thank you to Herve ang Georg for their help with contacts and numbers. Georg, I will contact your colleague but will wait a week to see if I can locate a spare,
Kind regards,
Brian
jwfdino
Post by jwfdino »
Hi Brian,
Are the brake boosters of 2 liter and 2400 Spider the same?
I have a used 2 liter Spider one.
Kind regards,
Jan
beebee246
Post by beebee246 »
Hi Jan,
Good to hear from you again.
I'm not sure, but I suspect they are the same. Just this morning I was offered a 2400 pump by a uk based member, so thankfully, I'm sorted now. But thanks for your offer,
Regards, brian
does anyone know where a replacement thermal element for the pump can be found/
The bi lame switch that is attached to the fire wall under the rubber boot and that turns of the pump when it runs fo too long due to a leak in the system.
Is there some kind of relay on the market that can be used as a replacement?
H
