Fiat Dino 2000 Parts Suppliers
Keen
Post by Keen »
We are currently restoring a 1967 Fiat Dino 2000 Cabriolet. As to be expected, there are a number of parts that were required. A pair of front Axle Spindles were ordered from Mr. Fiat with fitment confirmed before hand. Regrettably, when we attempted to install them, there was 1/2" difference between the mounting holes and the spindles were shorter as well. Mr. Fiat's representative offered us a store credit as a resolution which we found acceptable.
Would any of the members have previous experience with any of the European based suppliers? We are preparing a order and would like to ensure that all parts do fit and mitigate the requirement to return parts.
Re: Fiat Dino 2000 Parts Suppliers
Superformance in UK and Dino Parts in Germany are usually pretty good. However, there are still some issues with their parts. You may search for the parts you need here and can find threads like this: http://www.fiatdinoforum.org/viewtopic.php?t=1766
Post by Ribolla_67 »
Hello Keen,
can you please post apicture of the wrong spindle and the original part nr.?
I have a hunch what could be wrong...
Keen
Post by Keen »
Please find attached pictures of the spindles that's pretty request. As you can see, there is approximately half an inch difference between the mounting holes both horizontally and vertically. As well the spindle itself is noticeably longer. The black colored one being the original. It was suggested by Mr. Fiat that the could be modified. However, when it involves critical suspension components, we believe they should never be tampered with as their integrity would be compromised....many thanks for the responses...
Keen
Post by Keen »
I neglected to include the part numbers which are 4104944 / 4104945. As well, i have attached better pictures of the horizontal mounting holes and their distance for review. Many thanks.
abarth4
Post by abarth4 »
No way in the world could/should this be "modified to fit" My opinion. :o
Charlie Bates
Metamora Illinois, USA
Fiat Dino Spider 2400 #1186
Keen,
from your pics, I am pretty sure your Spider has knock-off wheels, and -if so - you
are not looking for the correct spare part numbers. See D3.14, below:
These front axle spindles are longer than the corresponding ones used for all Fiat
Dinos with bolt-on wheels (both Coupes and Spiders).
Keen
Post by Keen »
Thank you Dinoswede for your insightful response. I fear i may have a challenge finding replacements....
