Re: Hazard light system
Posted: Thu Nov 19, 2026 3:26 pm
When the Hazard lights are activated, the total power consumtion is close to
100 W, so a 16 A fuse is perfect. There is no need for an extra fuse.
The original 2400 Coupe fuses specification should be as below:
The "M fuse" is the best one to use here, according to this document. It is the
fuse designated for powering a radio, or any non-original 12 V equipment.
Comparing your description of your fuses with the original fuses specification
above, it seems like some tampering with the fuse box in your car has been
done. Or, maybe FIAT actually changed the numbering of the fuses during the
production run?
My suggestion is: look for a 16 A fuse not connected to any original equipment.
This ought to be the "M fuse"...!
Good luck!
production run?
Good luck!
