Thank you Tobi!
Br
Botond
Oils.
Benz 116 w
Re: Oils.
Hello lads,
Anybody can tell me an approxiamte oil pressure at 3000 revs? Mine is in the bottom third (around 25) and dropping...Do I just fill up? There is no leak, or unusual smoke coming out of the exaust....Thanks, Zsolt
Re: Oils.
You should always keep your oil level a little bit below maximum.
It cannot be guaranteed that the oil pressure reading is 100% accurate. To be sure that the oil pump is delivering enough pressure you should meter it with an accurate gauge.
Benz 116 w
Re: Oils.
Thanks Tobi!
