Cromadora wheels
Posted: Tue Mar 24, 2015 4:17 pm
by robmurray
My Dino Coupe still has what I assume to be its original 47 year old wheels. I have read that these magnesium alloy wheels become brittle and, therefore, unsafe. Should I keep them in use?
Rob
Re: Cromadora wheels
Posted: Tue Mar 24, 2015 6:48 pm
Nearly all of us do so. But it would of course be smart to check them for cracks regularly.
Posted: Tue Mar 24, 2015 10:23 pm
by Guzzi
Mag alloy wheels can become brittle, original Minilites are a good example. A lot though depends on the amount of magnesium in the alloy and for an application originally designed for the road (v competition a la Minilite) I think the wheels will be be robust. Perhaps contact Cromodora (http://www.cromodorawheels.it) and put the question to them?
Posted: Sat Apr 04, 2015 3:36 am
by mostromilano
The original wheels were, I believe, the "Elektron" alloy. They aren't as susceptible to cracking as they are corrosion - especially on the inside of the rim where the brake pad/rotor dust would be ejected. That, coupled with non-correct wheel balance weights (galvanic action), can cause the pimple and crater type corrosion that is common for mag wheels. Next time you have your wheels off, check the inside of the wheel where the brake dust would hit first.
DO NOT sandblast the wheels. If you do, they will have to be chemically dipped (Dow 17) again. That process is expensive and is similar to anodizing (but more expensive!!).
The best procedure for repairing and refinishing these wheels, if they are not too badly corroded, is to 1) thoroughly clean, 2) use an inert epoxy style filler in the imperfections (pockmarks, chips on rim, curb damage), 3) prime and paint with same type system (i.e. matched formula) paints. Avoid clear-coating the wheels if you want an original appearing finish. After painting desired color, re-mount tires without the gripper-style mounting devices as commonly found in tire shops and also avoid using clamp-on weights - instead use the adhesive backed plate style on the inside rim. Happy motoring...
Posted: Sat Feb 20, 2016 10:03 pm
by rossnzwpi
Here is a link to an illustrated guide to refinishing Dino wheels:
http://stevekouracos.com/restoration/ti ... storation/
Ross
