So what did you do to your Dino today?
The Dutch Dino
Re: So what did you do to your Dino today?
Checking valve clearances
Leo
Dino Coupé 2400x2
The Netherlands
Dino Coupé 2400x2
The Netherlands
The Dutch Dino
Or you might check if there is oil in your coolant.
Or if there is a lot of pressure in you cooling system when running.
Or try a leakdown test of your cooling system.
Or check for steam in your exhaust gasses.
All signs of a leaking head gasket. But then it is time to take the heads of anyway.
Leo
Dino Coupé 2400x2
The Netherlands
Dino Coupé 2400x2
The Netherlands
So I checked the chain tension and valve clearances today. The chains were slack. The r/h chain when moved up and down turned the outlet camshaft.
I think I have corrected the tensions. Then I check the valve clearances with the following results..
cyl in out
1 .12 .35
2 .11 .40
3 .11 .27
4 .25 .35
5 .15 .30
6 .15 .40
Cylinder 3 was the lower compression cylinder.
What do you make of this?
cyl in out
1 .12 .35
2 .11 .40
3 .11 .27
4 .25 .35
5 .15 .30
6 .15 .40
Isn't it great to have friends…
The Dutch Dino
Great story Dino John!
Thanks for sharing.
My little story for today is that I put in my gear leaver.
Thanks for sharing.
Leo
Dino Coupé 2400x2
The Netherlands
Dino Coupé 2400x2
The Netherlands
To be honest not today but last weekend I mounted my left cylinderhead as a part of my complete engine rebuild.
This weekend I start to put the right one together - my hands will hurt for shure after grinding in the next 6 valves...
...but hopefully I can drive my Dino again next spring...
Looking really good Thomas…Can't wait to see that red engine back where she belongs.
mostromilano
Wrapping up full rebuild of suspension and brake system...rear is done, need to install sway bar. Had to fabricate a couple of mandrels from tool steel for pulling hub bushings. New brake hoses, stainless lined caliper bores, etc. New gear oil + additive (need 2 small bottles!) for diff and trans as well.
Front end is waiting on bushings.
- Attachments
- rear suspen.jpg (54.54 KiB) Viewed 22118 times
- doublegarage
Today I replaced the boot lid (trunk lid) release cable.
I made my own up from parts bought at Flanders Co. http://www.flanderscables.com/
It works so much better now - very happy.
While my dino was out for repairing some previous damage i took the opportunity to fix my door hinges.
Plastic bushes in the hinges were non existing anymore, which resulted in excessive play on the door, so i just made some new ones myself from brass. Will last some time i guess.
Also found out that the door hinges are matching the serial number of my car because the number is stamped into the hinge, are the doors and boot also supposed to match the chassis? Found the number on the bonnet as well but so far not yet on the doors and bootlid.
