So what did you do to your Dino today?
Re: So what did you do to your Dino today?
Replaced my ground cable at the engine and the battery and cleaned electrical contacts at the alternator. I hope it cures the misfire when hot...
Leo
Dino Coupé 2400x2
The Netherlands
Dino Coupé 2400x2
The Netherlands
I tried to find a way to lubricate the clutch cable... It is not smooth at all.. I guess it is up for replacement...
Winter job.
Winter job.
Leo
Dino Coupé 2400x2
The Netherlands
Dino Coupé 2400x2
The Netherlands
- doublegarage
Leo,
I just did that job, not hard but some "patience required"
Let me know if I can help (or if it's worth a post)
Oh and...today I painted the top of my Fiamm Air Horn Compressor....
Put in my 'new' sun visors. Henrik on the dino facebook page mentioned some other guy was posting dino parts on ebay. I took a look and found the only two parts I was still missing for my project car!!
Leo
Dino Coupé 2400x2
The Netherlands
Dino Coupé 2400x2
The Netherlands
Tested if my misfire when hot was gone after replacing the ground strap at the engine.
Yes! Yes! Yes!
Yes! Yes! Yes!
Leo
Dino Coupé 2400x2
The Netherlands
Dino Coupé 2400x2
The Netherlands
Removed the rear trailing arms of my 2400 Coupe - the starting point of renewing my complete rear axle and suspension.
- doublegarage
Today I flipped the orientation of the driveshaft at the rear by 180degrees and was very happy to find that the vibrations when coasting were much reduced.
Dropped in an engine...
Leo
Dino Coupé 2400x2
The Netherlands
Dino Coupé 2400x2
The Netherlands
Over the past few days it has kept me busy:
-Cleaning grounds and adding ground cable to engine
-rewiring fuel pump
-checking valve clearance and camshaft lobes (good)
-checking engine compression (good)
-checking carb filters. (Bit dirty)
-opening carbs and checking: accumulated dust.
-cleaned all carbs. Started it again. It now sounds good. Time for a test drive.
-rewiring fuel pump
Leo
Dino Coupé 2400x2
The Netherlands
Dino Coupé 2400x2
The Netherlands
I did a technical check-up of the Dino before driving it for the first time.
Luckily I did, I found out that the fuel lines are leaking underneath the air-intake
So I replaced the fuel lines, checked compression, which was good. Tomorrow I'll check the rest....
