Hi Dan,
As you might know here in the Netherlands there is a company that is currently rebuilding 9 Dino motors, and i can only say that they do a really good job. They know the engines inside out and they threat these engines like they are working on a swiss watch.
If you decide to send your engine there, i know the guys very well end that company is around the block from my place. Beside that i am in Lübeck and Wismar once a month so if i can do anything for you (transport your engine or something) just let me know.
Stefan..Stefan2000 wrote:Hi Dan,
Thank you, I need an estimate on a total rebuild, cylinders, pistons, valves, balancing etc., would that be possible?
Dan
There should be some very good shops in europe able to handle any of the machine work. Superformance and Dino parts a good sources for parts...make sure whomever put the engine together is very familiar with timing the cams correctly.. Once the engine is out you might find it worthwhile to do other things...
I am restoring my car from the bare shell up..it has been a long process and i feel pretty familiar with mostly everything on the car..so if you need any help don't hesitate to ask.
Best Regards
hervé
Best Regards
hervé
Stefan, I´ll talked to Bart, at Nose2Tail, and I´m sending him my engine etc.DanHansen wrote:Stefan..Stefan2000 wrote:Hi Dan,
Dan
Thank you Hervé, I will...dinoverde wrote:There should be some very good shops in europe able to handle any of the machine work. Superformance and Dino parts a good sources for parts...make sure whomever put the engine together is very familiar with timing the cams correctly.. Once the engine is out you might find it worthwhile to do other things...
Best Regards
hervé
So, as I drained the slush (oil/coolant) I decided to remove the left bank camshafts to get a better view of the sprockets at the bottom of the engine, and there are also signs of damage, furthermore I noticed a pretty nonchalant use of liquid sealant...
Good news after all, I have decided to ship the engine to Nose2Tail, in Holland, they will do their magic..
- Attachments
- IMG_2164.jpg (57.29 KiB) Viewed 12402 times
- IMG_2168.jpg (34.18 KiB) Viewed 12402 times
Wow, looks like the roller bearing of the left cam drive gear just totally disintegrated causing the shaft to get out of line. And that caused the gear to jump until the piston hit your valves.
Makes me very sad to see this, such a nice and original engine and car.
But i'm sure these guys in Holland will do a good job, they have so much experience with these engines and they made all special tools to rebuild them so i'm sure it will be in good hands.
Yes, there is a bit of damage... But now I´m a bit more cheerful, finding the right workshop for the job, thank you for that lead, Stefan..Stefan2000 wrote:Wow, looks like the roller bearing of the left cam drive gear just totally disintegrated causing the shaft to get out of line. And that caused the gear to jump until the piston hit your valves.
This proves, that it´s not always a benefit to find a car that have driven no more than 1100 km per year the last 48 years....
So, next up, are to drop the engine, cradle it and ship it to Holland, and wait for springtime next year...
Dan, sounds like you will be in good hands. It would be interesting for the shop to take some more photos when they disassemble the engine completely so that perhaps we can all learn from it. Best to you, Luis
What a massive bummer! Bart does an amazing job though, so at least it will look and go better than when it left the factory
