2.4L Spider Seat adjustment lever backrest....
Re: 2.4L Spider Seat adjustment lever backrest....
Thanks, but a short „how to use“ would be helpful, I can‘t do or because I follow maybe the wrong buttons....
When you post a reply, you'll want to click on 'Upload attachment' (1). It then allows you to browse your computer for the file you want to attach (2) (the picture in this case), when you've done that you click the button 'attach the file' (3), now it should be attached. When doing so it'll delete the text you've typed, so you want to add the text after you upload the file(s). Hope this helps!
exactly this way didn‘t work !
which signs are activied by options when you use this way ?
I have selected the top four:
Disable BBCode
Disable smilies
Do not automatically parse URLs
Attach a signature (signatures can be altered via the UCP)
Disable BBCode
Disable smilies
test
- Attachments
- C8DC3540-3273-4F61-9B59-A89E469DB6EB.jpeg (51.77 KiB) Viewed 12041 times
I would be interested in a set as well
Work is ongoing
I have two way‘s
1. per Rapid prototyping, right one redesigned, per Siliconmolds
2. 3D datas from sample made, when finished I can mirror the data’s to the right Side, then 3D print
I wait in the moment in the solution 2., because need to know the pricing to comparasing 1 with 2
greetings
Peter
I have two way‘s
greetings
Peter
The seat levers are ready, just installed the left side into my car
Was a heavey work to get them designed, printed and installed
Adjustment slight pressure with glue and ready
Finishing work after printing is NOT included, that can be made by buyer, I haven‘t the time
Finishing is simple handwork
Price must be 35€ per part + shipping
The big black bloc will be take away after printing...
Hi Peter, did you make more than one set? I would like to buy a set if possible. Please PM me.
Hugo
Hugo
