Dino Spyder 2400 Gas Door Limit Bracket
2dinos
Post by 2dinos »
Hello.
Sorry I can't come up with more succinct nomenclature for the missing part. It is the part which controls the gas filler door closed position. Without it, the door would close beyond the body contour about 1cm.
The car is being restored and in need of the little stop which is secured with one screw into the gas filler wall (across form the hinge).
I've seen one poor picture, and it looks like an artistic little sculpture which may be rubber coated? I would appreciate any pictures that can be provided showing the gas filler box just opposite the hinge. Many thanks!
Re: Dino Spyder 2400 Gas Door Limit Bracket
Post by Fanalone »
Good morning, is this what you are lokking for:https://www.dinoparts.com/de/teile-zube ... dino-coupe
BR
Erik
Spider is a bit different than Coupé. For the Spider (2000 and 2400 should be the same) it’s like for the Fiat 124 Spider (Pininfarina). Look at Fiat Classic Parts Dealers Websites, quite cheap (below 10 Euro).
Post by Ribolla_67 »
2dinos
Post by 2dinos »
Excellent!!
Many thanks.
