Page 3 of 3
Re: hardware re plating. What is correct what is not?
Posted: Wed Oct 28, 2015 4:54 am
by dinoverde
Hi Richard
Can you tell me what the width of the material is? If you could post a picture of the back of the material.. I am thinking about having some reproduced.
Since we have access to such an original car , we should take advantage of it to try to reproduce of the parts not available.
I am also working on having the dash corner pieces reproduced. They are missing on most cars. Richard if you could post a picture..
Hervé
Posted: Wed Oct 28, 2015 5:21 am
by dino67
Many of these top latches have been chromed but it appears that on 3 very original late model spiders I've seen they are not chromed. Note strap behind.
Also trunk mat material underneath.
Posted: Wed Oct 28, 2015 5:28 am
by dino67
detail molding below rear valence and on sides of engine compartment lid. Known as either L5 or F1 on Re-originals" profile page for engine lid, a larger version for the valence in the rear, which were riveted on originally.
Posted: Wed Oct 28, 2015 5:31 am
by dino67
The small plastic pieces on the dash corners.
Posted: Wed Oct 28, 2015 5:45 am
by dino67
The proper plating underneath: Note; special exhaust clamps.
Original R.I.V. shocks and their true color.
Posted: Thu Oct 29, 2015 8:57 am
by dino67
Details on the piece between the dash and the door post.
Posted: Thu Oct 29, 2015 10:04 am
by HugoHarris
Many thanks Richard, this is such a valuable archive for our community.
Posted: Thu Oct 29, 2015 7:14 pm
by dinoverde
Thanks a lot so informative.. everyone should copy and save these pictures..
I am so surprised a bout the plastic trim on the side of the hood. I went and saw the car at fantasy junction and it has also the same trim..as well as the same trim for the trunk.. very informative..
Thanks again
Hervé
PS:If you could also post a picture of the back of the top limiting straps(with a width dimension)
Posted: Fri Oct 30, 2015 12:38 am
by dino67
The limiting straps look the same on the back and are 3". Glad to help.
