Tank spider leaks
alfredhamstra
Tank spider leaks
Post by alfredhamstra »
Hi all, my fueltank from my 67-spider leaks.
Is there a replacement for sale?
Superperformance has them, but price is high in my opinion...
Any ideas anybody?
greetings
Alfred, Netherlands
Fiat Dino Spider
nr. 239
Peter B
Re: Tank spider leaks
Post by Peter B »
Hello,
where is the leak ?
I got it in the area from the overflow pipe into the tank, easy to fix with metal glue
greetings
Peter
alfredhamstra
unfortunatly in the welding seam, where the two parts get together...
Fiat Dino Spider
nr. 239
Peter B
Post by Peter B »
there are enough companies around who can fix this....instead of new
Argonaut
Post by Argonaut »
There is one guy in Napoli who is able to create new tanks for the Dinos... but they come to the same price as from superformance.
alfredhamstra
I will take it out this weekend and see how bad it is. Ill check inside with a insidecamera.
If fixable, ill clean it from inside (lemonacid or something), take paint out from outside and weld the seem close.
Hope it works
thanks for all input
Fiat Dino Spider
nr. 239
ou probably can get it welded by a radiator shop and then have it resealed..https://www.gastankrenu.com
alfredhamstra
Thanks for all the input.
It was no leak after all!
The previous owner has put a return fuelline from carbs to tank.
He did not secure it in a good way: he put a hole in the tanksender and made a bad connection with....some rubber...
So when i filled the tank compl;etely, it overflooded from there
I took the returnline away anyway (not original for early spiders) and closed the hole with epoxy.
alfred
Fiat Dino Spider
nr. 239
