Fuel filler neck seal
Hi, I am looking for the fuel filler neck rubber seal for my 2400 Spider. This is part # 4046755 in the Dino 2400 Parts Manual. Does anyone have a source for this part, or suggestions as to what I can use as an alternative (or - very long shot! - one they can sell me?)
- Attachments
- IMG_1797.JPG (92.05 KiB) Viewed 4728 times
- IMG_1796.JPG (93.28 KiB) Viewed 4728 times
- IMG_1795.JPG (85.64 KiB) Viewed 4728 times
Re: Fuel filler neck seal
Hi Hugo,
I can’t be sure but I think coupe and spider share the same fuel filler neck shroud, and if they do, there is one for sale on this forum. It appeared over the weekend. Take a look at the sales/wanted section.
If you find someone that will repair the heater matrix please let me know, as mine has seized shut!
And if you are offered a spare unit that you don’t want,again, I’m your man,
Cheers, Brian 1319/1470
Took my 2400 spider for a very spirited run yesterday. That did me a power of good.
Hi Brian,
Good to hear from you! Mark Devaney has found someone to re-core my matrix so best get in touch with Mark.The filler shroud is different for the Spider, but happily is available here http://www.cicognaniguarnizioni.it/
My five year restoration is in its final throes - maybe we can get our Spiders together over the summer?!
Hugo
Hugo
