I have not found a good reference for torque tightening specifications. If one exists, I would appreciate a link, otherwise, what are the torque specifications for:
Cam cap nuts, M6x1.0. Grade is either no longer legible, or not stamped on nuts.
Cam end bolts [the ones with the 24mm hex head]
Cam cover nuts
Nuts securing 8mm studs on top of water pump and related plumbing.
Thanks, Ben.
Torque tightening specifications 1967 coupe 206
Re: Torque tightening specifications 1967 coupe 206
Have a look at this: viewtopic.php?f=19&t=26
You should get the original documentation with all the technical specs.
Be aware: there is a wrong torque specification in the technical specs: torque for the cam Schaft bearing covers is NOT 3,3!
I torque them as normal M6 with 10-11.
KR Thomas
KR Thomas
