Soon, the door cards for the '67 coupe I'm working on will be complete.
Should I cover the entire inner surface of the doors with vapor barrier?
Vapor Barrier for Coupe Doors.
johnharrill
- Dino: No Dino (yet)
johnharrill
Re: Vapor Barrier for Coupe Doors.
Bueller? Bueller?
cover the door..the point is to seal the water that can come from the window opening.. make sure your drain holes at the bottom of the door are opened..use 3m black soft sealer so you can remove the barriers if needed(sold in strips)
johnharrill
I'll try the 3M black silicone.
The door cards are not yet ready and I still need to install the door checks.
