Tyre pressures
Tyre pressures
Hi, I'm running brand new Michelin XWXs on my 2.4 Spider. Can anyone advise on optimal tyre pressures please? p3 of the Specs and Features manual (http://www.fiatdinoforum.org/download/file.php?id=658) specifies 27 PSI front and rear. Seems kinda low to me..
Re: Tyre pressures
This seems to be pretty low indeed. I usually pump up to 33 psi.
Re: Tyre pressures
Many years ago I learned a "trick" from an old tire guy:
1. Pump up all the tires to std. Pressure
2. Put one stripe of thin tape (like Cellofix packing tape) across the tire surface of all 4 wheels.
3. Drive 1 - 2 km on tarmac (mileage depends on road surface), make a stop and inspect the wear on the tape surface.
The wear pattern on the tape, will give you an ide of tire pressure & wheel alignment, but you may have other preferences for comfort/ vehicle behavior
