More Dino parts 2
More Dino parts 2
Here some more parts and a list of parts.
Dino parts list
6 cylinder heads 2000 2400
1 intake manifold DCN 1 DCN Weber carburetor Various parts for Weber carburetors
17 bumper corners front rear with dents
1 set of bumper coupe very good
About 50 new wiper blades and 20 wiper arms Dino Coupé Spider
1 set of brake calipers Dino 246
40 Various instruments DINO Coupé Spider 246
10 reflectors, 6 door handles, some with keys
interior lights
2400 coupe dashboard
Oil pumps and snorkel Dino engine
Various engine parts DINO
50 camshafts + 4 sports cams
40 lamp pots for headlights in front
6 front grilles + headlight rings Dino Coupe 2.4
2 hat shelves coupe
6 door panels coupe 2.4
8 panels rear coupe
4 center consoles coupe
8 doors with frame coupé
6 exhaust parts Spider + Coupé
10 magnesium rims Cromodora DINO
2 tanks 2400 2000
2 differential housing
4 new suspension springs 2400
Axle parts various 2000 + 2400
2 squad shaft parts
2 cooler expansion tanks
6 heaters with fans
oil pan parts
10 sets of chrome parts for the coupé door panel
20 chrome strips outside and inside windows DINO Coupé
14 Chrome frame front rear window window DINO Coupé
8 B-pillar aluminum panels Coupé
2 sets of seats Dino 2000 rear black
Seats complete 2400 front and rear grey
2 gear bells 2000 2400
3 gearbox housing and spare parts with ball bearings 2000
40 various air grilles above rear Dino Coupé
8 hand brake lever
4 steering columns
40 window regulator mechanism
Amateur ventilation parts
4 rear windows complete
1 windscreen DINO Spider
60 different switch lever frame coupe
Interior equipment Dino Coupé Spider various
5 window regulator motors
Mechanism with ropes
8 Dino Coupé controls for lights and wipers
30 different headlights Carello Dino Coupé
3 hoods 1 tailgate dino coupe bad
2 chrome headlight rings 2000
100 relays various Dino
20 ashtrays front and rear Dino Coupé Spider
6 taillights NOS Dino spider
Rear light lenses NEW Coupé
2 rear lights complete 2000 coupe
2 parts rear seat cover Dino Spider 2000
Brake booster BONALDI
10 wheel bearings new
3 taillights complete Lamborghini Urraco / Jarama NEW
8 calipers rear and front 2400 2000
24 exhaust manifold Dino Fiat
various gas linkage CARBURETOR complete
60 new brake pads Dino 2.0 + 2.4
Many Sleeve shock absorber 2400 rear
EXTRA:
Dino 246 E engine block good condition
2 Dino 206 cylinder heads numbers original verified
Dino parts list
interior lights
2 hat shelves coupe
8 panels rear coupe
2 tanks 2400 2000
2 squad shaft parts
6 heaters with fans
oil pan parts
8 hand brake lever
4 steering columns
EXTRA:
happiesttrees
Re: More Dino parts 2
Would you happen to have a Bank 1 Cam Cover? I found a crack in mine today for the 1970 2400 Spider. Thanks!
1970 Fiat Dino 2400 Coupe
1970 Fiat Dino 2400 Spider
1967 Fiat Dino 2000 Coupe
1967 FIat Dino 2000 Spider
1967 Fiat Dino 2000 Spider
1968 Fiat Dino 2000 Spider
Hi Alfredino,
I'm interested to light black plastic for the console fiat dino coupe.
Did you still have in stock ?
Marco
Marco
Hi. Do you have the original Cardera windshield wipers? If not is the rubber in good shape which is all I really need. You can contact me at solomed at gmail. I'm in California.
Perry
Perry
Hello!
I'm looking for a complete dashboard with instruments for my Fiat Dino spider 2400.
Please send me photos to w.e.schiessl@icloud.com
Kind regards, Werner_1
Hi Alfredino,
Is this list still current? Or has it just been pulled forward by members who didn’t see it a few years ago!
I must admit I fell into the net, because I PM’d and got no reply!
Hello.
Looking for two of these Choke Cable Brackets, P/N # 4192667 (for two different cars) in the attachment.
They are the same piece for 2000 and 2400 cars.
thank you.
thank you.
No longer need the choke cable bracket.
Now I seek:
The black "FIAT" horn button in perfect condition. Several companies are trying to reproduce them....Fingers crossed !!
Also...
Looking for a source for the Dino Spyder side molding clips. The moldings are available in stainless steel and are very nice, but the clips I think must be re-used, and they do not survive removal and corrosion attack very well. They are rather unique. Google search has not revealed any sources yet.
Many thanks!
Now I seek:
Also...
Many thanks!
Can you be more precise about the molding and its clips? I have various clips in a box and would check if I knew what you mean.
