Radiator ventilator switch
Ciao tutti,
At the bottom of right case of the radiator there is the switch that activates the relay for the radiator fan.
I have several versions of this switch, with different on and off values. On 92-86°C, off 87-76°C
Which switch is factory original for the Dinos 2400? Which switch / values do you use, if different from factory original?
Thank you for your input
Bijan
Re: Radiator ventilator switch
Post by Bijan »
Hi Georg,
just a hint: Dinoparts sells a Mahle TSW1D as replacement, it shows 75° 70° on the outside. Interesting, if I compare it to your values.
I still use the original switch and will look up the temperatures next time when I am in the workshop.
Bijan
