Dino coupe 2000 specs
dinoparker1021
Post by dinoparker1021 »
Hello to all. Just joined the club as I cannot find much information on the internet, in fact I cant find information anywhere .
I have bought a Dino coupe 2000 1968 which to most people should have been scrapped but I push on replacing just about everything. I have rebuilt the engine and would like to know if anyone has the torque setting for the con rod to crankshaft and the head bolts as I have put new rings and valves to the head but cannot find these settings. Thankyou in advance
Barnfind
Re: Dino coupe 2000 specs
Post by Barnfind »
Find all the info for the 2000 coupe here.
viewforum.php?f=19
Good luck with the restauration. (Pics, please)
Please get yourself a Workshop manual. They are available and for such an expensive and complex Engine a must have. Can't unterstand to Start an Engine Rebuild on a dino Engine without proper literature. Conrod to crank should be 75Nm (w/o warranty). KR Thomas
Barnfind
Post by Barnfind »
ThomasK wrote:Please get yourself a Workshop manual. They are available and for such an expensive and complex Engine a must have. Can't unterstand to Start an Engine Rebuild on a dino Engine without proper literature. Conrod to crank should be 75Nm (w/o warranty). KR Thomas
Agree..
Looks like you should get first af all al the documentation that you can get, before starting such a project. Bear in mind that these are uncommon cars, right parts are scarce and expensive, and if you whant to do a proper job and keep close to the original you are spending a lot of time and money. Better to do things right. Take it easy..
