hardware re plating. What is correct what is not?
Posted: Mon Jul 27, 2015 3:26 am
				I would like to start a discussion here concerning what are the correct finishes for the different hardware parts for a 2400 fiat dino spider.
I have finally embarqued on what promesses to be a long and tedious restoration on my 2400 spider. I sold my 2liter and my 2400 coupe for what will certainly be not a cheap endeavor. But i will try my best to make this car as new and correct as possible.
The car is currently being striped of everything.. Bare shell. I will do all the assembly work and most of the mechanical work(I have restored a couple cars in the past ..the last one being a 67 xke coupe.. a lot of parts on an xke..)
Then all the hardware will be refinished hopefully with the proper finish. cadmium, or black phosphate.
Where it get's tricky is to decide what is right and what is not. There are not too many pictures available of original cars that show all these details. Some factory pictures are colored drawings and most of the documentation i have to not clearly show those details. I am calling on this board to share it's individual knowledge regarding original finishing on original parts.
I have seen brake calipers,refinished in clear cad color(grey) and some in yellow car(gold). My inclination is to powder paint all the metal suspension parts satin black. Yellow car all the bolts marked fiat,and have all the engine nuts and bolts clear cad plated. I wonder if like on jaguar there was any logique regarding hardware colors. Some of the carburetor linkages appear to have been yellow cad,..but again with the passing of time they could have been clear car or even black phosphate..It would be great if we could put our common knowledge and establish some clearer idea of what the original cars were like.
As far as the engine block color I have a factory pamphlet that shows the block, the drive shaft yoke and the water pump pulley as being bright red.. What should it be?
As for the valve covers..they are now a gold color.I know they have been redone. I have seen black one and on my brochure they are silver.. I understand that 2400 valve covers for the 2400 were aluminum, but my car being a very early 2400 it never had the electrical brake vacuum pump that kept air in the vacuum tank. The passenger valve cover does not have the proper fitting to hook the line that goes to the pump. So it still could have magnesium valve covers. This car does not even have the electric brake lines that go to the front brake pads.However it has the double piston front calipers.
Should the hardware on the engine compartment firewall be a certain color?
I am planning to reuse as much as the original nuts and bolts, and i use a very good outfit in Los angeles that is very good with reconditionning automotive hardware.(techplate).
If you have information to contribute to my request please share them and if you can also post pictures it would be great to document all this. After all there is going to be less and less original cars with this factory details, so we should all benefit from finding out now what is correct and what is not.
Hervé
Hervé
