OP sensors - Washers
johnharrill
Post by johnharrill »
The engine is now running and I am chasing down fluid leaks. The big one is on the exhaust cam (Distributor side) rear cover plate.....the hardest to get to.
Will remove the cam cover tonight and re-seal it, and get better purchase on the heater hose clamps, which leak as well.
The only other leak is from both oil pressure sensors.
Should there be a copper washer between the sensors and the block? :?:
