As the name suggests I'm looking for an AEC101 case.
It most likely won't be easy but just givin it a try.
Sorting out if I could get them reproduced and that's why I need one. Now I have a functional one myself but don't want to tear it apart and remove the lables etc.etc to have them reproduced. Don't mind the shape it's in.
I have a spare AEC103 case already so i'll might give that one a shot as well.
To persuade someone to part with it, I have a spare coil for my dinoplex, it's a 3 terminal BAE202B coil that (according to adrians dinoplex website) could be used as a replacement for the original BZR205A coil. I would be willing to part with it if someone is willing to part with his dinoplex housing.
						Wanted: Dinoplex AEC101 case / housing
Re: Wanted: Dinoplex AEC101 case / housing
Stefan,
I have a late production run 2400 coupe but it has the aftermarket equivalent of a Dinoplex ignition. I am thinking about replacing it with a AEC 103a box but with Adriens Bosch upgrade inside. Original look but with modern reliability! So if the new solid state stuff can be packed into the 103a chassis, I would be interested in purchasing a copy.
Bert
Bert
Yep, that would be the idea, if it's a good copy it should fit.
Might try to figure out if I can change the internal section of the lower part from the AEC103 a bit to make it easier to build an MSD unit in there (for a points system).
I think most important would be the AEC101...the AEC103 should be possible to order through Superformance as well, worst case scenario would be to order it complete with ignition and than ditch the internals and keep the case.
