Yellow warning light on dash
Discussions and Socializing
bertjones
Post by bertjones »
When I started to drive home on Sunday after exhibiting my Dino coupe at Ferraris on Fifth in Naples (Florida), I noticed some dew had formed on the rear window so I decided to use the heated switch to see if it would burn off. Well, the glass did get warm enough to clear the haze but I noticed a yellow light was showing on the dash (just the the left of the steering column). I had thought this only indicated a low output of the alternator but my digital meter (installed in the ash tray) indicated I was charging at 14.1 vdc. As soon as I switched off the rear window defogger the light went out.
Does everyone else see the same thing? I'm more puzzed than alarmed--just didn't know that was a indicator light for the defogger.
Bert
Re: Yellow warning light on dash
Strange! It seems as if your rear window heating Indicator lamp is working as intended ;)
Just refer to #48 in the wiring diagram.
