steering boxes
grega
steering boxes
Post by grega »
Hello,
Does anyone have a solution for worn out steering boxes?
Greg A
Re: steering boxes
Post by Ribolla_67 »
Hi Greg,
ZF steering systems was taken over by Bosch last year.
Nevertheless, they still care about older Zf systems.
Maybe you try the following adress ( this friendly man gave me recommendations about correct oil)
Good luck!
Ribolla
Angelo Cardinale
Automotive Steering, Small Scale Business (AS-SSB/ENS2)
Robert Bosch Automotive Steering GmbH | 73527 Schwäbisch Gmünd | Richard-Bullinger-Straße 77 | GERMANY | www.bosch-automotive-steering.com
Tel. +49 7171 31-7936 | Mobil +49 160 4714451 | Fax +49 7171 31-67936 | Angelo.Cardinale@bosch.com
grega
Re: steering boxes
Post by grega »
Hello,
i was under the impression that all the dino's had the same Gemmer steering box.
some have a ZF system?
Re: steering boxes
The Steering Box is a ZF Gemmer Steering.
All Fiat Dinos have the same one.
Bearings and Seals are available, other spare parts not.
The Steering box can be adjusted in two ways, with the screw on top and with the thickness of sealing/washer at the side.
Maybe you can get an improvement by cleaning and proper adjustment.
How do you define wear in your case?
Worst thing that can happen is real wear on the surface of the roller - that is difficult to fix and spares are not existent.
Maybe you can get a used steering box somewhere in that case.
Hope adjustment will get proper improvement.
KR, Thomas
