Plastic parts needed for 2.0 Coupe
outofaustin
Post by outofaustin »
Find below pictures of two parts which I need for my 2.0 Coupe. A third part I don't picture but I describe it.
1. This is the spacer that lives between the window frame and the inner door frame. This is a picture of the one that lives in the right door. I need its mirror image that lives in the left door.
2. This is the grillwork that lives in the air outlet in the front fenders. I have the one for the left side but need the one for the right.
3. I don't picture this part: it's the tube through which the wiring harness travels in the door jamb. I need one; it's the same side per side.
Again many thanks in advance for any leads.
Ben Schotz
2.0 Coupe 1463
Ft fender side vent screen.JPG (102.88 KiB) Viewed 7549 times
Door to window frame spacer.JPG (86.25 KiB) Viewed 7549 times
Re: Plastic parts needed for 2.0 Coupe
The grillwork inside the air outlet in the front Fenders does not look original. Someone should post a photo of the original grillwork. Unfortunately i am away from home (and may garage) at the moment.
Greetings, Thomas
outofaustin
You're absolutely right, I think. I mistakenly posted a picture of the metal screening that a previous owner had installed for the missing plastic grill. Find below a proper picture of the one I have. I need the right side one.
And I also attach here a picture of the wiring loom tube that lives in the door jambs. I need one.
Thanks for noticing.
Ben
door jamb wiring loom tube.JPG (121.54 KiB) Viewed 7524 times
Ft fender grillwork.JPG (115.35 KiB) Viewed 7524 times
Hi Ben, I think I can help. I have sent you a Private Message.
outofaustin
Hi Georg
Again Thanks. I sent you a private message with my email address and where I live.
Best
Ben
