Dino engine vs Fiat 130 Coupe engine
Hello, is there something same in these two engines? Design? I have been told that 130's V6 is based on Dino's V6.
What's the truth?
What's the truth?
Re: Dino engine vs Fiat 130 Coupe engine
As far as I know, it's only the number of cylinders which they have in common
Thats exatly my thoughts but I have prove it some how. Cannot use Wikipedia now because it says they are related
Peter Tabmow
I do not think there is any commonality in the two engines technically, but there is a link: I believe the great Aurelio Lampredi adapted the racing Dino engine for the Dino range of road cars and also designed the 3.2 V6 for Fiat.
There is a link, Lampredi, yes but different engines! I think 3.2 was the latest version and 2.8 first?
Peter Tabmow
Correct, but I believe the 130 Coupe only ever had the 3.2...JPohja wrote:There is a link, Lampredi, yes but different engines! I think 3.2 was the latest version and 2.8 first?
Emanuel H
I once owned a beautiful 130 Coupé, the first thing I had to do was to replace the cam belt. That is already quite a difference to how the cams are driven in the Dino...
Emanuel H
..and to my recollection the 130 V6 has a 60 degree angle, while the Dino has 65 degrees
So only really same thing is number of cylinders as before stated
If I recall correctly Mike Morris comments on the similarities in his book. FIAT, when undertaking the joint Dino project would have liked to incorporate some of their modern engine ideas such as shim-over-bucket cam followers & belt cam drive but Enzo insisted on race-proven conservative design. FIAT designed their own V6 (the 130) at the same time, unconstrained by the need to race it and choosing parameters more suited to a luxury GT. The cylinder banks could be at the more logical 60 degrees and the block made from prosaic cast iron. A single carburettor would suffice as well as a single cam per bank. The rev limit need not be as high with the balance shifted to even spread of torque rather than high end power. Most 130s were automatics and did not have LSD diffs although some were fitted with the ZF 5 speed. I also remember reading about the 130 V6 being used in a racing X1/9.
cheers
Ross (in NZ)
cheers
Ross (in NZ)
