Wanted: vent window hinge
Post by Scalino »
I’m looking for a passenger side vent window hinge for a spider. I’m not sure wether the coupe has the same one.
Below is a picture of the one that came off the car (the broken one) and one for a 124 Spider, which is shallow by about 3mm. I could make the 124 one work with a spacer, but I would prefer an original one as no modification to the rubber is necessary.
Re: Wanted: vent window hinge
Post by Scalino »
Anyone?
fiat 124 spider will work..
try this link:https://www.ebay.com/itm/FIAT-124-SPIDE ... Sw3bBckL7E
Post by Scalino »
Indeed you can make it work, but it’s not the same. The 124 one is pictured on the right in my photo!
alfredino
Post by alfredino »
I have only a complete triangle for a Dino Spider!
Best
alfredino
Post by alfredino »
Here a photo of Spider triangles, one side w/o glass!
Post by Scalino »
Hi Alfredo, thanks for the offer. I made a spacer, so I should be able to get it to work for now. I do want a correct hinge in the end, so I’ll keep this in mind for the next time I place an order with you!
