Brake and reverse lights not working?
mbuzz20
Post by mbuzz20 »
I just did some servicing on my 2.0 Spider. Seems that now the brake lights, reverse lights, and drivers door little orange light are not working. The headlights, front and rear turn signal lights are working just fine. Anyone have any idea of what is going on? Could it be the fuses, and where are the fuses for these lights located? In the panel just inside the drivers door, and if so, which ones? Anyone out there have a diagram of the fuses marking which is what? If not the fuses, any other ideas of what the problem is? Thank you, appreciate any help!
Re: Brake and reverse lights not working?
Maybe this helps: viewtopic.php?f=19&t=110
