My 2.0 has been making some sounds that worried me. Today I discovered that the timing gear at the bottom of the front of the bank with the spring tensioner is apparently broken. The out side gear is not in fixed contact with the inside gear. I need to replace the gears on both banks.
Does anyone have a suggestion as to places to find them? Thanks for any help.
Timing Gears for 2.0
